Transfer G8F Morphs to G8M
faisanfaisan Posts: 602
edited June 2021 in The Commons
Is there a product or a way for transferring Genesis 8 Females Morphs to Genesis 8 Males?
Post edited by faisan on
    edited June 2021
    Is there a way? Yes. Long route though.
    So the short route is dial the morphs into G8F, and dial in the hidden G8M shape [or if you have the free transgender shape, dial that it as it's rig was likely adjusted].
    And then you'll tell us no  no it 'must be' ... and like the long route is to make clothing shape of each figure, dialing in various morphs and exporting out .obj files and using Morph Loader Pro to bring them back into a figure as a morph.
    And then eventually you'll probably come back with but the such and such doesn't fit, and like yeah no kidding. That's what 8.1 was invented for to take care of ;-)
    It's rather hot and humid over here, don't mind me.
    There may be a product but I don't recall if or where it is. Are you wanting the entire Gigabites collection transferred to him, or just a particular character?
    Post edited by Catherine3678ab on
  • HavosHavos Posts: 5,705
    This free script will transfer morphs between G8F and G8M (and vice versa). https://github.com/TugLLC/GenNext
    It works pretty well, but will struggle with some extreme morphs (eg highly stylised or monsters)
  • faisanfaisan Posts: 602
    I want to transfer Sasuke Morph for Genesis 8 Female to Genesis 8 Male. What is the easiest way?
    edited June 2021
    When I want to transfer the morphs, there's nothing in the window list, so I can't transfer anything. What am I doing wrong?
    1366 x 768 - 213K
    It is been a while since I used this script, but you have to favorite the morphs you want to move. This thread has more info https://www.daz3d.com/forums/discussion/176271/morphs-from-g3-to-g8/p1, look at the last 10 pages or so for info on this script.
    BTW you might not be able to fully transfer Sasuke, as I was under the impression that the eyes are a geograft, not just a morph (I maybe wrong as I do not own that figure). This script will transfer the morph, but not the geograft, so will not be the same.
    edited June 2021
     I have Sakura 8, not Sasuke which is based on Sakura 8. Can confirm that yes the eyes are geografts. Non-transferrable. And I imagine that the entire thing was enough work the first time 'round that is possibly why Sasuke was made as a morph for Sakura 8.
    IF there were no geografts involved, the basic concept would be to make a clothing piece from G8M's BASE mesh [no eyelashes] FOR G8F. When exporting the .obj - NO groups. G8F would be dialed to the hidden male morph and when making the clothing she's the donor, the clothing is target. Her situation is "current" ... and then down the list of options 'reverse' morphs or something [sorry, forgot how it was worded atm - just found out my brother is in the hospital having reacted to the 2nd vax, he's not good, my mind is elsewhere but trying to hold on here]. Any way, after making "clothing" from the G8M's mesh, then dial OUT G8M shape, dial in the desired morph to transfer. [oh yes, G8F must also be already BASE mesh only, NO eyelashes]. HIDE all figures except the clothing which should be looking like the desired character to transfer. Export out that mesh [no groups]. [size settings, whatever you send out has to come back in the exact desired size] Now then load G8M, base resolution, NO eyelashes. Using morph loader pro [somewhere under Edit] bring in that clothing piece and make the morph. REVERSE deformations! Name the morph, for the moment is okay to leave it under Morphs ... you could place it now or later elsewhere under Actor ... I like to make sure that they are working before losing them under Actor. Yes to a control, whatever settings you would normally use for making morphs. And then hopefully it "takes" and appears over on the Parameters Tab. As you dial it in, G8M would be looking like the female character. Dial it in 100%, go to the bones editor tool, right-click on a bone. Edit ... adjust bones to mesh ... then back on the Parameters Tab, on the concerned dial, right-click [edit mode] and select ERC. Everything is left as is, make sure the 3 boxes at the bottom are checked also, Accept. Dial OUT the morph, File > Save As > Support Assets > Morphs ...
    Clear scene load in fresh G8M, dial in new morph, have fun :-)
    The eyes are indeed props. They are like the G8 lashes are, and parent into place. So they could potentially be used on the males. You will need to hide the normal Genesis eyes. However, I don't know how well the eye props will work on the male figure. Did somebody make a Sakura eye prop for males? There was a whole big discussion on making a male version of Sakura back at the time.
    You may be interested in this thread which has some links to some characters made to be Sakura counterparts.  https://www.daz3d.com/forums/discussion/228581/free-character-presets
