Creating a new morph from an existing one.
I want to give Genesis 8 female some noticeable abs with bodybuilder details. But I only want it to affect Abdomen lower and abdomen upper.
Is there a way I can modify the bodybuilder details so to duplicate it and have it affect only Abdomen lower and upper.
I want Abdomen Lower and Upper at 200% but the rest of her body at 100% (As I don't like how her legs look at 200% with that morph)
I've made custom morphs with dformer. But not sure if that can be used to edit existing morphs.
  • Richard HaseltineRichard Haseltine Posts: 111,332
    Are they HD morphs? I've a feeling they are, and if so they cannot be edited. If not you could do it manaully by export as OBJ and then using Morph Loader Pro with a weight map from a dForm to control where the morph loaded, but then you'd probably also be looking at additional corrective morphs needing to be split and linked to the split bodybuilder.
    There is also https://www.daz3d.com/shape-splitter , but again it won't work for HD morphs.
    I don't believe so. It's a base morph for genesis 8. Bodybuilder details.
    How can I tell if it's HD or not?
    Several of the base morphs are HD, even some included with the base figure are. Check the file list - if /data/daz 3d/genesis 8/female/morphs/some folder has a .dhdm file for body builder details it's HD, if theer is only a .dsf file it isn't.
    .dsf. I can use that morph kit you reccomennded. Just gotta wait for it to go on sale.
    Thanks a bunch.
