Problem with geoshells
Hello
I recently applied hecate enchantress horns to my genesis 8 character. then i tried to add hooves from cc avandrael but as  soon as i did this the horns on the head lost their texture. is this because the hooves geoshell seems to span over the whole body and as soon as i add them then the horns are offset? if i change the offset of the hooves geoshell then i can fix the horns but then the hooves offset is too low.
is there a way to fix this somehow or are those two items incompatible?
  • Richard HaseltineRichard Haseltine Posts: 112,109
    If you select the a Geometry Shell you can selectively tirn it off, by group or surface, through its group of properties in the Parameters pane.
  • thanks a lot! everything is working now.
