replacement for 'lighting model'?
Previous versions of either DAZ or certain items  have had a 'lighting model' variable on the surface, where you could select plastic, metal, skin, etc.  I cannot find it now.  Does it still exist?  Does it only exist for certain surfaces?  Is there a replacement?
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
  • Richard HaseltineRichard Haseltine Posts: 112,224
    Lighting Model is a property of the 3Delight Daz default Shader, it controls how highlights interact with the rest of the surface (and in the case of the skin setting it enables SSS). With other shaders the same result would be achieved by editing the relevant properties directly, or using some of the pre-made shader presets for different effects.
