Filter by Context
Anyone else have problems with the filter by context block? I check it and it doesn't filter the content associated with the highlited figures. Any idea why this is happening?
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
  • There are no log errors. This is windows 10, I actually went and deleted the updates... Not any particular figure, but all of them. I have added a screen shot to show that I have the figure which is a Genesis 8 character chosen along with the poses and function, and there is nothing. I have purchased probably 7 different pose packs with the Gen 8 female characters...
    1718 x 905 - 2M
    edited May 2022
    Redacted
  • PekenPeken Posts: 37
    I have the same issue, some random stuff is shown in both Products and Files, most of the categories missing too.
    Uncheck it, and all goes back to normal...
  • Yes... When I uncheck the box, all the submenues come back... Only does when I check to filter by context...
    edited May 2022
    Redacted
    Thanks!
    OK, did the DB Maintenance - Re-Import Metadata and that fixed the problem.
    But added one other - now the Smart Content sorting is all messed up, but I can live with that smiley
  • DB Maintanence ???
  • Richard HaseltineRichard Haseltine Posts: 112,113
    BrianJasonStone said:
    DB Maintanence ???
    Content Library option menu (the lined/hmaburger button in the top corner, or right-click the tab)>Content DB Maintenance
  • No maintanence option... Do you have a screenshot???
    1744 x 1008 - 1M
    The button at top-right of the Cobntent Library pane,  between the greyed maginfying glass and the Viewport tab.
  • Did the export on all metedata, then reimported. That worked for a little bit then went back to the same....
