Render artefact (solved)
AndroolAndrool Posts: 85
edited December 2014 in Daz Studio Discussion
I have artefact on V6, olimpia and lilith when I try to do a render, I tryed variouse skins, preset of light, camera and render and the only thing who change the probleme is to make the render image biger.
this is a render of v6 out of the box, just clothed.
http://www.hostingpics.net/viewer.php?id=973571artefact.png
g2f didn't seem to be afected neither is genesis.
Any clue?
Post edited by Androol on
  • Richard HaseltineRichard Haseltine Posts: 112,183
    The image isn't very clear, but it looks like an SSS shader issue - you need to adjust Shading rate and/or Shading Scale for all surfaces with the same GroupID. Using the Surface Selection tool, from the Tools menu, right-click on one of the skin surfaces and then from the menu click Select Surfaces with Value.., then pick GroupID. Now go to the Surfaces pane (Window>Panes(Tabs)>Surfaces) and adjust the settings.
  • AndroolAndrool Posts: 85
    Thx it solved my problem. I have to find the right tuning now.
