Problem with transfer utility
Hello everyone! I created a shirt as an .obj file and applied it to genesis 8 with the transfer utility but when I move the arm I have this defect in my armpit. how do i fix it? thank you.
745 x 559 - 310K
  • Richard HaseltineRichard Haseltine Posts: 112,268
    You might be able to deal with that by smoothing or adjusting the weight maps, or it may be that you need more geometry in the armpit area to share out the stretch. A wireframe image might help, and seeing how the shirt sits on the figure (is it loose under the arms).
  • iacoposk8iacoposk8 Posts: 76
    Thanks for your answer. I tried with a model with a high density of vertices but it always gives me the same problem
    3840 x 2160 - 5M
    How close to the skin is the shirt in that area, in the zero pose?
    It required some pJCMs. First "create" the clothing .duf file, then make some pJCMs to counter the JCMs in the figure.
    No charge ;-)  https://sharecg.com/v/97315/view/3/PDF-Tutorial/Making-pJCMs-for-Clothing
