Exporting from Daz to Sculptris?
I have just started dabbling with Daz Studio 4 (free version) and Sculptris 1.02. I found that I can export a model from Sculptris to Daz but not the other way. Is there a way to do this that I have not figured out?
Thanks
What format are you using from Sculptris to DAZ Studio? Is it OBJ?
You can export from DS to Sculptris using OBJ as well.
By the way, there is only the free version of DAZ Studio.
When I try to export as an OBJ, Sculptris does not appear as an option.
The fact the Sculptris does not appear, is only a matter of the scale.
I don't know what unit of measurement Sculptris uses, but it is not really important, as long as you export from Sculptris again at the same scale.
Try one of the other scales and. see how you get on, Poser for instance or Blender? Someone else may be able to help more with the correct scale to use, but give it a try.
I figured it out. Export as an OBJ, open with Sculptris. When I brought it back to DAZ it came in really tiny, but that's fixable.
Anyway, I'm merely a hobbyist; just fooling around with this stuff for personal creative ventures.
Thanks for the help.
Select the same scale for importing and exporting, you should be able to get it right that way.
What Scale did you export from DS at?
http://www.daz3d.com/forums/discussion/10974/
Export and import from/into DS at 100% scale. When you are importing into Sculptris deactivate "Dont resize" option. That should fix rescaling to tiny.
