Somebody know why this error in fbx export?
doriangdoriang Posts: 13
edited December 2014 in The Commons
I'have this error when export fbx model with pose and import in 3ds.
What is wrong?
  • Richard HaseltineRichard Haseltine Posts: 111,341
    Please post an image showing both figures in grey, the texture isn't needed to show the problem and is against the forum TOS.
  • doriangdoriang Posts: 13
    do you mean the figure inside DAZ3D?
    This is so as I bought it from the site. I do not know how to make it gray.
    In 3ds i removed the texture because it uses too much ram.
    can you help me?
    It's okay like this?
    1000 x 516 - 270K
    nobody can help me????
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,498
    You may need to wait a bit for a reply, not many use Max here.
    But
    I get funny joints sometimes on FBX export to iClone if the figure uses JCMs (joint controlled morphs, Blendshapes in Max).
    If that is any help.
    I cannot really fix it just hide it under clothes etc
    You may need to apply [those morphs or use whatever Max has for ERC.
    How DAZ does it is here
    The problem is only when I export the model with a pose. If I export the model in "T" pose I have everything working correctly :/
    Please don't bump threads - as wendy says, this isn't a chat room and it's not unusual for a reply to take a while.
    In this case, I think your issue is probably a limitation of FBX, and quite possibly the destination software even if FBX was more obliging. The DAZ figuers in DS use separate weight maps for each rotation, FBX and the limited number of 3D suites that I know use a single map, so going from DS to one of the other applications via FBX always involves some compromises. You can get a preview of the result by using the Edit>Figure>Rigging>Convert to General Weight mapping command in DS.
  • jorge dorlandojorge dorlando Posts: 1,159
    I really can not tell if this will be useful for you but wonder:
    already tried a conversion using this ?:
    http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=22694909
    But I notice: have not used it
    thanks guys i tried this but same error... i think is daz3d 4.7 the problem because i have this error with all figures
    with version 4.6. I had not this error.
    Somebody can sy me where i can find the 4.6 version of daz3d?
  • Same issue, for a game developer any good way out?
