Skye is missing!!!
Leo ChenLeo Chen Posts: 697
Is there anyone have successfuly installed the following three Skye related products?
1. Dynamic Skye Hair
2. Skye Developer Pack
3. Skye Danger Pack
I just can not locate these 3 products with DAZ Studio.
Since "Dynamic Skye Hair" is for Carrara, I can understnad why.
But how the other 2 products are missing!? Hiding?
PS: my DAZ3DIM shows all these 3 products has been downloaded.
  • TotteTotte Posts: 15,244
    If you right click the entry in DIM and do "Show Installed Files..." you will see where it was installed.
  • Leo ChenLeo Chen Posts: 697
    Thank you,Totte.
    I know these products have been downloaded in my Mac and which folder where these 3 products has been installed.
    But I can not see these products in DAZ Studio.
    edited December 2014
    Thank you,Totte.
    Are they to be seen in DS? I thought the hair is for Carrara and the setup set is to be loaded i hexagon to create clothes from.
    Post edited by Totte on
    Totte said:
    Thank you,Totte.
    Thank you,Totte.
    I can not locate all these 3 products in my DS.
    Yes, the hair is for Carrara.
    They are not found in "smart content", but in the Content Library: Poser formats->Figures....
    If you do as Totte says in his first post, it will tell you exactly where the items were installed to.
    Skye Danger Pack should be found in Poser Formats > Figures > 3DUniverse
    Thank you,JimmyC_2009.
    You are a good helper.
    I found them.
    1274 x 771 - 176K
    1273 x 695 - 181K
    It is weird I Just could not locate all these products using "search engine".
    PS: use "Skye" as keyword. Just show only "Puppy Love Poses" at that time!
    Now, it can locate "Skye Developer Pack" but "Skye Danger Pack" is still missing!
    It is not in "Data Base of Products"?
    1268 x 876 - 429K
    Post edited by Leo Chen on
    It may be an older item with no Metadata.
    It might show up if you use File instead of Database as shown below?
    600 x 215 - 52K
    As you wish! :)
    The result is as attached images.
    827 x 789 - 114K
    806 x 598 - 105K
    Now, puppy is also missing!!!!
    Of course, silly me, Puppy doesn't have 'Skye' in the filename so it wont appear that way.
    Try searching for 'Danger' under File, and you should get the Danger Suit, then try it again using Database instead of file, and see if it turns up there?
    You are right.
    The keyword must be "Danger"! :)
    760 x 837 - 290K
