Using Geometry Editor on instances.
EZ3DTVEZ3DTV Posts: 1,682
edited May 2021 in Product Suggestions
Feature request
I would like to be able to select an instance group, select the geometry editor tool and use the marque tool ane delete grass and other partial items without having to ungroup the instances.
An instance group should be able to contain partial, edited, orphaned instances.
When I ungroup the instances, Daz sits there in a cyclical stutter trying to use iray on each instance.
It would be nice if the geometry tool worked on instances.
It would be nice to be able to select and delete items or parts of items within instances without having to ungroup the total package.
Surgical editing.
Post edited by EZ3DTV on
  • EZ3DTVEZ3DTV Posts: 1,682
    edited May 2021
    Also, I would like to purchase more Daz body hair products for men.
    The ones that exist are nice but they are often difficult to work with and often the hair is either too long and the opacity or hair sizing is usually not very well implemented.
     It is nice to click apply and have everything applied all at once. But then again, it is nice to be able apply only nipple hair and discrete patterns elsewhere.
     This is not for porn per se, it is for men who often go shirtless or dress only in shorts in many situations.
    Very high quality body hair patterns for men is a product very much in demand from my perspective.
    I would love to purchase a very large collections of body hair items for men that would work very well with Michael 8.1 HD, backward compatibility would be nice too.
    Body hair with many styles and color options especially in the blacks, blonds, reds and browns ranges.
    A very highly comprehensive body hair compendium product for men would go nicely with the Daz offerings already in circulation.
  • zombietaggerungzombietaggerung Posts: 3,955
    This: https://www.renderosity.com/rr/mod/bcs/oh-my-body-hair-for-genesis-3-male/119035/ is quite good for body hair and works fine with g8. And had lots of presets to hide parts for under clothing.
  • chris-2599934chris-2599934 Posts: 1,986
    The whole point about instances is that they're cheap copies of the source object. Once you start being able to edit the individual polygons of each item, you're no longer talking about instances.
    edited May 2021
    I understand that Chris, but when you have to only edit one clump of grass you have to undo the entire group and then you end up with a memory overload.
    Then daz goes into a cyclical stutter with iray and your project is corrupted.
    This is where having what I have outlined is helpful.
    Have you ever tried to ungroup a group of instances that have thousands of items in it just to delete one clump of grass?
    It is often impossible.
    Being able to select that instance of grass and delete it without ungrouping the whole instance group would be helpful.
    Or being able to alter a few instances without having to ungroup the whole ball of wax would also be helpful.
    Also, being able to draw a square around objects in the viewport should be available too.
  • Richard HaseltineRichard Haseltine Posts: 111,816
    Even if you uninstacne the item its geometry iss till an instance of the same asset as the others, it's just able to take modifiers independently - if you want to use the Geometry Editor, which edits the asset data directly, you need to break that link, e.g. by exportijng as OBJ and importing with a new name so it isn't pointing back to the original asset.
  • AscaniaAscania Posts: 1,856
    And that's why InstaEdit exists. https://www.daz3d.com/instaedit
    As well as Instances to Objects. https://www.daz3d.com/instances-to-objects
    edited May 2021
    Have you ever tried to use instaedit on an ultra scenery ground object?
    You take one grass group and use instaedit and end up with 7000 or more instances of grass.
    Your computer bogs down, Daz freezes up (and I have an Nvidia  3090 graphics card) and Iray flips out and won't stop resetting itself.
    Why can't I just delete one instance without converting the whole group?
    If I were to use Geometry editor on an instance why can't Daz just ungroup that instance and leave the rest intact?
    If I export the object I end up with defeating the purpose of the grouping.
    There should be a way to surgically edit members of the group without having to convert the whole group to a mass of redundancy.
  • UthgardUthgard Posts: 902
    Completely agreed. The ideal, for me, would be to be able to ungroup and select instances found inside a given volume so we could easily make our own selections.
