• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Morphs move object around
robograaf2robograaf2 Posts: 40
May 2021 in Blender Discussion
I have a problem with trying to create a morph for a static object in blender and exporting this to Daz Studio.
I'm trying to make these two red circled things adjustable in height:
So I export the thing as a .obj using these settings:
The import it into blender like so:
I change up the model like so:
Then export it like so:
Load it as a morph on the object like so:
And then this happens, when the morph is at 0 it looks like this:
But when the morph is at 100% the entire thing moves in the weirdest way, ends up somewhere else entirely, but the model is changed properly:
I'm sure i'm doing something wrong that is terribly obvious to most, but I can not figure it out, and there's not a lot of help to find online.
Is there anyone who can explain to me what's going wrong here and how to fix it? Would be hugely appreciated!
  • Richard HaseltineRichard Haseltine Posts: 111,929
    May 2021
    You are using Custom settings in the DS OBJ Exporter, the Blender preset in Morph Loader - the axis settings don't match, so the model gets flipped. Assuming you don't want to have to redo the work in Blender export another OBJ (anything, you will cancel it anyway) and in the options dialogue click the Save preset button at top-right. The reload your morph, and this time select the preset you saved from the export dialogue.
  • robograaf2robograaf2 Posts: 40
    May 2021
    Wow.. I must've been really dense.. I was quite sure I tried every single setting and was driving myself crazy, but you're right..
    I now made sure to select blender preset during both exporting from daz and importing in daz and it worked just fine..
    One more question though, is it normal that when I export something from Daz to Blender the object always imports into Blender at a 90 degree angle like so:
    Cause this is something that always happens to me, and when I forget to put it at 90 degrees again afterwards it messes up the morph / object as well..
    Any clue?
    May 2021
    By default Blender, like 3D Studio, uses Y axis front to back and Z axis going up - most other applications, including Daz Studio, have Y up and Z back to front. That's why both have options for reassigning the axes. The Blender exporter option in DS allows for this but in fact you have your Blender import/export options set to use the same system as DS, so the net result is a flip. You could use a different preset for export/import in DS, using the more common axes (I don't say correct because in fact the Blender/3DS system is what is used in maths) or you could chnage the Blender options to match the DS system (in both export and import dialogues).
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
