normal map
Hello!!! is it possiblke to use normal maps in C8,5 pro? and how??? thank you for help!!!
You can load a normal map in either the bump channel or on the displacement tab of the shader. "Normal Map" is one of the selections in the drop-down and you just load your normal image map there.
Mark
In C8 we have this option in each channel…
True, but does it actually do anything in any other channel?
I just tried loading one in the color channel and it didn't do anything. At least not loaded as a Normal Map. If I just load it as a Texture Map it looks pretty crazy and cool but doesn't work as a normal map (as far as I can tell).
Mark
You are right, the tutorial of Marcello Teixeira is a good exemple : https://www.youtube.com/watch?v=n3xocEZSTRE
