Combine morphs
jedijuddjedijudd Posts: 606
Is it possible to combine multiple morphs and save it as one morph
  • Richard HaseltineRichard Haseltine Posts: 112,009
    Yes, as a controller that will set the underlying morphs. You don't want to literally bake all the morphs to one as you will lose all the links that make them work with poses and other morphs.
    1. Set your desired shape up, with everything else zeroed
    2. Right-click in the parameters pane and enable Edit Mode, if it isn't
    3. Right-click in the group you want to place your slider in and select Add New Property
    4. Fill in the dialogue with the name you want, set limitsd as desired, etc. and click Accept
    5. Set the new slider to 100%
    6. Right-click on the new slider>ERC Freeze
    7. In the dialogue check that the Sub components look right - if something is in there that shouldn't be deselect it - click Accept
    8. Check that your new morph works correctly
    9. If it does, save - if you want it for more than one scene set its value to 0, then use File>Save As>Support Assets>Morph Asset to save (the Author and product entries in the dialogue will be folder names in the /data/figure/morphs folder if you want to back the files up separately)
  • jedijuddjedijudd Posts: 606
    Thank you Richard
