Converting files
super_joelsuper_joel Posts: 118
Is there a way to convert AVM files made with QAvimator version 0.1.0 to be used in DAZ? It occurred to me that I have a ton of stuff there that I could use as a foundation for more stuff in DAZ. If the files were an identifiable type for DAZ to read that is.
  • Richard HaseltineRichard Haseltine Posts: 111,913
    Assuming they are 3D files, you would need some way of converting to OBJ - that sounds a fairly obscure format, so you may find only the original application can do it.
    I had a look on Google for this.
    It may be possible to just rename the file extension to 'BVH' and import to DS directly. although they may not be much use for anything, depending on what model was used to create them?
