Partial morph
The GYN-01 uses 1 morph slider. Is there a way to disable just the head morph?
  • Matt_CastleMatt_Castle Posts: 3,298
    Alas, no, as DaveYabbo's products rely heavily on HD morphs, which are not editable by end users.
  • Silas3DSilas3D Posts: 836
    Shape Splitter is very useful for separating morphs, but it won't work with HD morphs.
  • margravemargrave Posts: 1,822
    There is a way to remove vertices from morphs using the Geometry Editor (I think), but I don't remember how to do it.
  • Richard HaseltineRichard Haseltine Posts: 111,816
    Again, it doesn't work on HD morphs. However, for future reference you need to make the morphs favourites, and have nothing else favourited (heart icon on the slider), then select the areas you want to exclude (you will need a vertex selection but it may be simpler in some cases to select polygons and then covnert by right-click menu); once you have the vertices selected and the tool in vertex selection mode the right-click menu has a morph editing sub menu with the command to remove selected from favourited morphs.
