Content Library
SherrillSherrill Posts: 61
Just upgraded to 4.7. Where did my content library go? Cannot find the menu (ie. My Library, DAZ format. Poser format, etc.) Type in a description in "search" - Nothing??????
Thanks in advance for any help provided.
    If you can see the Content Library pane, but there is nothing in it, then you need to look in
    Edit > Preferences > Content Library > Content Directory Manager
    and make sure that the path to your library folder is listed as BOTH Poser Formats and DAZ Studio Formats there.
    Can you please post a screenshot of your Content Library pane?
    When you upgraded to 4.7, did you use DIM or install it yourself? Did you install PostgreSQL, and run the conversion program from Valentina/CMS?
  • SherrillSherrill Posts: 61
    Thank you. Paths are correct for both formats. I did use DIM to install. I did not install PostgreSQL that I am aware of. Here's the screenshot, but it doesn't respond on any buttons I click. :down:
    1920 x 1032 - 411K
    You have accidently closed a window in the pane, see image :)
    1920 x 1032 - 191K
    Sorry!! BTW - I checked my DIM log and PostgreSQL and the Valentino conversion files were installed.
    1920 x 1032 - 436K
    The only time I have seen something similar to this, is when a new version of DS was installed with the previous one still open.
    You may need to uninstall DS, and reinstall again to fix this. It only takes a few minutes with DIM, and if it still doesn't work, we can take it from there.
    Thank you so much. Will try this tonight!
  • fixmypcmikefixmypcmike Posts: 19,744
    There are two little click bars -- click the lower one, just above where it says "None"
    Thanks Mike! Perfect !!!! And thanks again to you Jimmy. Was going bananas and would have never figured that was 2 click bars. Thought it was just one. I am so happy now. Maybe I can get some work done!!!!!!!!!!!! :)
