Changing the Diffuse
Angel_2232633Angel_2232633 Posts: 1,204
This has always been kinda annoying, but I never mentioned it. Don't ask why.
But in Daz, when I change diffuse color, like the mats on the floor or something. It don't change if the file name is the same.
Is this a setting, a glitch or a temp file thing?...
  • fixmypcmikefixmypcmike Posts: 19,743
    If you edit a texture but use the same name, you need to refresh images -- Ctrl-i
    Textures are usually the largest files being used, and DS doesn't waste resources reloading them unless you tell it to.
  • almahiedraalmahiedra Posts: 1,375
    You need refresh. In surface tab, right click, menu is diplayed, click in "refresh images" option, there is also an "automatically refresh images",
  • Angel_2232633Angel_2232633 Posts: 1,204
    I figured it was an easy fix. I wasn't sure what to do though.
