LIE
carrie58carrie58 Posts: 4,180
Where do I find it??How do I use it,if I want to make a layer to add to a texture ??????I have a headache!!
  • srieschsriesch Posts: 4,243
    In the Surfaces(Color) pane, click on the image thumbnail to the left of whatever parameter you want to add another layer to (for example, the Diffuse parameter.) From the context menu, select "Layered Image Editor".
    Click the '+' button (middle right) at the bottom of the list of Layers, then select "Add Layer" from the context menu to add a new layer. Click on it in the list to select it. For the Resource parameter, click the button after it (initially labeled "None") and browse to and select an image you want to use for your layer.
    At this point it probably depends on what you want to do, but perhaps for the "Blend Mode" parameter you might want to experiment with the different options in the dropdown button to see what effect you want. If there is something specific you are trying to accomplish and you can't figure out how, let us know what you are trying to do here and we can provide more information.
  • carrie58carrie58 Posts: 4,180
    OMG!! Thank you so much Sean ....I don't know how many times I've looked and NOT seen ,but thank you I'll probably be asking something again but,you've given me something to work with.
