iray render issue
khryss666khryss666 Posts: 42
so here is the issue is you look at pic 01 ... it renders fine ... but then all i do is rotate the object ,.. then rendeds as transparent ..
ive tried wit cpu only ,,, gpu only .. fresh install of software , os , and drivers ...
minimal loaded just figure and skin ... this shouldnt be happening
any help wiuld be appriciated
(im on a asus rog strix gl702vm
i7-6700
32 gb ram
gtx 1060 6 gb
DAZ 4.15)
992 x 485 - 38K
989 x 365 - 25K
Post edited by khryss666 on
  • Richard HaseltineRichard Haseltine Posts: 112,113
    Rotated on which axis?
  • khryss666khryss666 Posts: 42
    richard ... im not good with axis's (i have to trial and error every time when trying t augnent things by axis) ... i grabbed the rotation box in top right corner of viewport anf drug fromt of box up ... (sorry)
    i believe the white line in second pic indicates floor ... and even though the floor "appears clear" ... you cant render through it? ...
    anyone confirm this?
    edited April 2021
    That was my thought, try turning Draw Ground off in Render Settings.
    If you are using the cube then you are not rotating the object, you are chnaging the point of view.
    yep that fixed it it was the ground ... thanks (also thanks for info on point of view)
