Model center point
大家好,如何随意更改模型的中心位置
联合编辑 不能正常工作
957 x 940 - 232K
  • Richard HaseltineRichard Haseltine Posts: 112,268
    That looks as if you have loaded a morph which was made with the figure moved forward from its default position. If that is what happened, the best solution would be to try to line the OBJ for the morph up with the default figure position, export the OBJ again to make the new positon permanent, and then import that OBJ as the morph.
    看起来您好像已经加载了一个变形,该变形是通过将图形从其默认位置向前移动而制成的。 如果发生了这种情况,最好的解决方案是尝试将变形的OBJ与默认的图形位置对齐,再次导出OBJ以使新的正子永久化,然后将该OBJ导入为变形。
