(SOLVED) Daz Studio Not rendering
caberotcaberot Posts: 15
edited April 2021 in New Users
Daz 3d will not render for me. I tried changing the default render library to a parent folder of my Daz Studio Library as well and that did not fix the problem.
Suggested here: [solved]Daz Studio stops responding for a minute on render start and save - Daz 3D Forums
This just started happening as soon as I came back from a business trip and updated the drivers on my graphics card. I have an NVIDIA GeForce RTX 2060 as well as an Intel(R) UHD Graphics 630. It doesn't necessarily go into not responding. Just after 10 minutes on a stand-alone render with no background it's still at 0% completed. I've tried uninstalling and reinstalling Daz3D 4.15. That didn't solve the problem.
Did I try turning off the collision and smoothing modifier suggested here: Massive CPU load on a particular scene, how to identify the hog? - Daz 3D Forums
I'm running Windows 10 32.0 GB of RAM 31.5 GB Usable and a 64-bit Operating system
Post edited by caberot on
  • Richard HaseltineRichard Haseltine Posts: 111,758
    So this is Daz Studio? Rendering in Iray? What devices do you have seelcted for Photoreal in the Advanced tab of Render Settings? Assuming it's just the GPU, the 2060, does deselecting that and selecting the CPU help? Can you render a simple primitive (Create>New Primitive)? If it won't start rendering the render library setting isn't a factor, and if you can work until you start rendering I doubt it's a Smoothing Modifier-rlated issue.
    How did you update your GPU drivers, where did you get them from?
  • caberotcaberot Posts: 15
    edited April 2021
    Richard Haseltine
    So this is Daz Studio? Yes. Was that sarcasm? Because I put that in the title. If it was, very funny. I got a sense of humor. You're alright man.
    Rendering in Iray? Yes
    What devices do you have selected for Photoreal in the Advanced tab of Render Settings? Both CPU and CUDA 0-GeForce RTX 2060.
    Assuming it's just the GPU, 2060, does deselecting that and selecting the CPU help? No
    Can you render a simple primitive (Create>New Primitive)? Yes
    PerttiA
    How did you update your GPU drivers, where did you get them from? NVIDA GeForce experience and Intel Driver and support Assistance.
    I'm trying to render the Zhao Genesis 8 female character. When I remove her, I can render again.
    I figured it out. It was the subdivision levels with the Zhao Character. Lowering the subdivision levels helped. I was able to render again.
    Zhao
    Resolution High
    Sub D level 1
    Render SubD level 2
    Zhao makes my computer not responding - Daz 3D Forums
