Compositing trick, difficult to explain
araneldon
Would it be possible to construct a shader such that when applied to a plane it will cause everything behind it to not render, and the plane itself would also be invisible?
sounds like a shadowcatcher function of some sort, I think I could do this in carrara not sure of studio
basally your plane needs to match your background globally in texture or absence of texture
Something like pwCatch?
http://www.daz3d.com/pwcatch
Edited to add: yes, I think?
http://www.daz3d.com/forums/discussion/30173/
If it also works when there is no backdrop, then yes.
Thank you for replies :)
Sounds like you want a so-called "holdout" material for what you would need a bit more than a mere shader. In that case you might want to try that one:
https://sites.google.com/site/millighostmix/home/holdout_matte
Exactly that. Thank you very much :)
