Problem default Mouthrealism
Any gen 3 character I load is messed up. I narrowed it down to mouthrealism morph, default is at 100%. I did what was suggested on here and changed it through gear option and then saved but it still comes back as 100% default no matter what. Any ideas what I'm doing wrong? Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,939
    Saved how?
  • JImWJImW Posts: 33
    As a morph asset
    The trouble may be that Mouth realism is - as I recall - an HD morph and so won't save as an asset (I'm not sure if it will update the base settings though). How did you install? If you installed through DS then resaving won't overwrite the default file, and will be ignored on load.. Mouth realism doesn't have any general effect on the figure, so I am surprised it is causing major issues. What is the problem you are seeing?
    All characters are loading in ugly or distorted. I found another morph, Navel, that was at 100% default also. That won't save at zero either.
    I installed manually
  • Unless you can show us a screenshot of whatever loads distorted I don't think your problem is with those two morphs.
    If I were you, I would enable showing hidden properties and check those -- perhaps you have a 3rd party morph which is setup incorrectly and is responsible for the distortion you are talking about.
    If you do post an image, please put the Viewport in Smooth Shaded mode or put clothes on the figure.
