UltraScenery System
The simple question is, does UnltraScenery System work in DAZ Studio? I ask because I don't want to waste cash on something that needs another program to work. Also, I'm not familiar with the .DSE file designation.
This looks good but I want to be sure before buying it. Thanks much.
  • margravemargrave Posts: 1,822
    Yes, it's completely encapsulated inside Daz Studio. There are no outside programs, as far as I can tell.
  • GoggerGogger Posts: 2,535
    There is a whole thread here with tons and tons of example renders, and information, including detailed explanations on what it is, what works, and what else is required.  Some add-ons require an outside purchase, i.e. an UltraScenery add-on pack that features Pine Trees requires these pine trees to use, but that is well documented and not a hidden thing at all.  UltraScenery is great to use as is and can do wonders, but if you want to expand your scenery abilities you can get the add-ons, or not - your choice!  If you get the UltraScenery Accelerator it will blow you away how much faster generating a scene is than without!
    You should check that other thread out. If you don't say "WOW" at least once a page UltraScenery may not be for you.
    https://www.daz3d.com/forums/discussion/466351/ultrascenery-new-territory-commercial#latest
  • alexhcowleyalexhcowley Posts: 2,411
    To slightly elaborate on one of Gogger's points: the very first post in the above thread contains a link to the original thread.  The first post in the original thread contains a detailed list of most of the add-ons, with any required products.  This list was not quite up to date, the last time I looked, but it should still be very useful.
    The fact that Ultrascenery has spawned a second support thread tells you pretty well everything you need to know about it.
    Cheers,
    Alex.
  • pzrldraltpzrldralt Posts: 30
    Thanks much everyone. I do a fair amount of outside scenes and what DAZ offers is limited. This system with a randonizer as I read it was exactly what I was looking for.
    Regards, Robert
