How do brows works ?
LBOLBO Posts: 0
Hi ! New user here !
For the moment I'm trying to tinker with the differents assets that I have to create my own combinations.
For the moment, hair is fine, eyelashes are fine, bodymorphs are fine... but i can't seem to make the eyebrows I have work.
I seem to have 2 problems mixed into one :
1 - When I add new brows from the "anatomy" section, the standart one stays in place. Is there a way (both easy and free) to remove them ? For the moment the option that I have found are : manipulation in GIMP, bying a 20$ tool, having a models that come with this tool (i don't have one at the moment).
2 - When I add a brow (on top of the basic one) to test, and i try to change the color using the options given in the material folder, it always seems to crash :/ Does someone knows what to do.
Thanks you for your time, and sorry for my lack of skills ^^'
  • Richard HaseltineRichard Haseltine Posts: 112,059
    Check to see if the character you are using has a No Brow (sometimes just NB at the end of the prset name) - not all do, and then you are stuck using other solutions, but many do.
  • LBOLBO Posts: 0
    Thanks so mush for pushing me to return to the folder and hunt for a No Brow / NB option, now i could find it by doing the proper researchs !
    Then the reson the script was failing was simply because the new brows were not properly attached ! I'm such an idiot !
    Guess i'm really just bezginning to learn. ^^
    Thanks again for your time !
