obj & mtl files
I recently purchased an item in an obj format. I was able to download the mtl file associated with it. However, when importing it into Carrara, it didn't appear to have the mtl file map onto it. Is there a seperate step I need to do to apply it? I was under the assumption that the mtl file wouold automatically apply itself. Any thoughts about this?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,813
    it varies a lot depending on the mtl file itself
    or how the obj file references it
    Carrara usually asks you to locate the textures if it reads the mtl and doesn't see their path but I do find with some it doesn't
    if it's too many maps to manually load you may be able to edit the mtl in notepad though I suspect it is the obj file (which also can be edited in notepad) not looking for it
  • StuieStuie Posts: 58
    I'll take a look and see what I can find out. Didn't know about using notepad on them. Thanks, will let you know what I can find out.
    edited March 2021
    save as all files not txt btw
  • PGrePGre Posts: 95
    edited March 2021
    Check the .Obj file for this as well (from the .0bj wiki page)
    Vertex normal indices without texture coordinate indices
    As texture coordinates are optional, one can define geometry without them, but one must put two slashes after the vertex index before putting the normal index.
    f v1//vn1 v2//vn2 v3//vn3 ...
    Post edited by PGre on
