DIM default install sets - installation failed
DIM default install sets - installation failed --
I am doing a complete reinstall of Daz after a total system wipe on my pc... no daz files or content survived the wipe so...
installed 4.15 and all its required components (i think) using DIM and get the above message. affected items are "interactive lessons for daz studio 4.10+", "DM's Memorial DS", "Secret Garden Shaded Haven" and "Dark Fantasy Weapons for G3 and G8 Females".
Do I actually need these for DS4.15 to work correctly? If So - how do I get them to install?  all other product packages I own download and install just fine. If not needed, how do I disable this automatic que?
  • For DS to work, you don't need those items.
    There are several different reasons that a particular asset might not install through dim.
    First, try redownloading the item, you might have corrupted files, then try reinstalling.
    If that fails, Try a manual download of those items from your product library in My account and try unzipping them directly. This is just a test to make sure they aren't corrupted, if you get an error, it might mean the download is corrupted and need to submit a support ticket regarding the items.
    If you don't get an error, move them to you download directory for DIM and overwrite the existing files and try installing again.
    If that fails, you can always manually install the items.
  • thrain9thrain9 Posts: 106
    @DMP - thanks for the answer and tips. since they are not needed, i will just skip trying to install.  bookmarking so i can find this again if i need to install something critical.
