RAM Memory Problem
Roland4
Does anyone know of a good free tool with which I can clear the RAM Memory ?
Roland4
i hope the link works or even shows up! ....im not fully sure how to post links on this forum :)
Which link ???
bugger! ...it didnt work then :( ...ok just type "rammap" in google for me it was the first one in the list its from "technet"
let me know how it go's for you...or of course if you need some help with it :)
I dont understand, what this programm do.
i have found this.:
%windir%\system32\rundll32.exe advapi32.dll,ProcessIdleTasks
they are 2 files you dont really want to play around with!
Sorry, but i dont no what i must do with this programm. My english is not so good that i can understand this.
might be safer to just leave it as it is then
Surely just restarting your computer will clear the RAM?
IF it's the Brcye memory stack you want to clear, just saving and closing Bryce and then reopening it does it.
I have found this. A command line command.: %windir%\system32\rundll32.exe advapi32.dll,ProcessIdleTasks
Opinions vary on what that command will actually do ... http://arstechnica.com/civis/viewtopic.php?t=369399
Might I ask why you feel you need to clear out RAM? Usually the Operating System will unallocate any 'dangling memory' when the owning process terminates, assuming the process does not do that itself. Circumstances when RAM usage just keeps on increasing can be down to something called a 'memory leak', where a running process does not clean up after itself.
Sometimes, when the memory is full Bryce crashes. If I shut down the computer and then back up, then everything goes back to normal.
Yes, Bryce is a 32-bit application and can therefore only address 2 GB. Bryce keeps everything in memory, also up to 16 undo steps and when saving compresses the file in memory before it is written to disk. Saving the file often and always with a new name, then quit Bryce and restart it, then load the saved file will free unused memory, like the undo buffer. Also note that if you click on an object in the library, it is loaded into memory even if you don't use it and leave the library. It is good practice for an elaborate scene or one that needs memory intensive objects to run Process Monitor and monitor the memory usage of just Bryce. The Task Manager can be misleading and sometimes it blocks some commands.
Thank you for your detailed explanation Horo. This shows that there is ultimately only one way to get free the memory, and that's to start Bryce new.
If you have not already done so you can make Bryce running in Windows LAA (Large Address Aware) which will permit it to access a little bit more of your PC's memory (assuming it is available). Not sure of the exact amount but it's around an extra 500MB or so I believe. Won't solve the underlying problem but may act as a bit more of a buffer for you (and Bryce).
Thank you, for your details. This I have done some time ago, and am more than satisfied with the result.
Thank you, for your details. This I have done some time ago, and i am more than satisfied with the result.
you can allocate a small portion of your hard drive's free space as "Virtual ram" also :) ...that helps for me running memory chewing software :)
Thanks.
@Tim Bateman: That would work for Bryce if Bryce could use the hard drive. But as Horo's has said many time, Bryce does everything using memory. It'd be wonderful if Bryce used the hard drive for virtual ram.
GussNemo
Bryce may not use virtual memory but Windows does. If Windows detects that memory is getting critical then it will start moving stuff from the memory into virtual memory to free up memory space. The bigger this space the more it can release. The more memory Bryce has available the more it will use without using virtual memory. I have had Bryce doing big renders and DAZ rendering in the background and not had any problems, slow but not crashing. The time for Bryce to crash usually is when I try to save a big scene, usually after adding two or three extra elements, or when I have forgotten to save it for a while :)
I use these on my computer and also the first one on my Android Tablet.
This first one also has a system monitor that sits on the desktop with a button for cleaning ram.
http://www.iobit.com/advancedsystemcareper.php
http://www.iobit.com/iobitsmartdefrag.php
@ Fishtales- thankyou for explaining that for guss....thats exactly what i was trying to say but i left out the smaller details :)
So Windows is monitoring how much Ram Bryce is using, and when Bryce calls for more memory Windows then moves other programs to Virtual Memory?
Basically, yes.
http://windows.microsoft.com/en-gb/windows/what-is-virtual-memory#1TC=windows-7
It is also better to have the page file on a separate drive, not a partition on the same drive, from the system, program and data drives if possible, Especially system and programs. That way the hard drive heads don't have to thrash across the plates trying to do two or three things on the one drive. It should also speed up hard drive access. Also remove the paging file from the other drives and set it to the highest the other drive will allow. It will still only use what it needs even if it is a massive amount.
