Misaligned Textures Issue when using a product from Cayman Studios
Epic82
in The Commons
I’ve applied the materials for Gia 6 to Genesis 3 Female with Cayman Studios’ Legacy UVs for Genesis 3: G2F that can be purchased at Renderosity. While Gia 6’s textures have applied mostly well to G3F, some of the textures on the right shoulder, arm, and hand are misaligned, as you can see in the renders I’ve attached to this thread. Knowing that some here might have purchased Cayman Studios’ other products, like Legacy UVs for Genesis 8: Genesis 2 Male, Michael 5 and Michael 6, that are available at Daz, has anyone ever encountered a problem similar to this and found a solution to it?
981 x 881 - 351K
981 x 881 - 1M
It's not a problem with the Legacy UVs product, it's due to the textures you used: they don't use G2F UVs as Gia 6 has her own custom UVs.
You can use the Map transfer tool in DS to transform those textures into textures using G2F UVs, and then those will work properly with the Legacy UVs product.
Thanks for your comment, Leana. How do I use the Map transfer tool? And where can I find it? I've never used it before.
Hello, Epic82. RobotHeadArt put together a very useful tutorial to deal with this situation:
https://www.daz3d.com/forums/discussion/95701/tutorial-converting-custom-genesis-2-uvs-to-genesis-3
