Gums
davidjones8418
I can't seem to mess with the gums on a G8F (Victoria).
I am trying to alter the Mouth surface using LIE but not getting anywhere. Nothing changes.
However, I did use Easy Teeth to remove a couple of teeth. It is the gums under there I want to mess with. Should be some bloody pits if a tooth has fallen out I think.
https://www.daz3d.com/easy-teeth-for-genesis-8-female-s-and-merchant-resource
Does anyone know if Easy Teeth moves the gum surface texture map or something? Or makes it impossible to manipulate?
How are you using the LIE?
Via the Surfaces Tab >> Mouth >> then going through the base colour selection, adding layers there
I sorted this out in the end by upgrading to Daz 4.15, where it seems to work okay.
