Saving Props
This has always bugged me and I never found an answer.
I use a lot of OBJ objects that I make in Blender. And sometimes I have one of those objects parented to another of those objects. For example, a spotlight housing with a movable bulb object inside, and the bulb is parented to the housing.
And I want to save that as a Prop in D|S. Now apparently you save a Prop as a Support Asset/, then Figure/Prop Asset. But it only saves the parent object, not both. I then made the major mistake of saving the selected spotlight objects as a Support Asset/, then Scene Asset. Big mistake. It proceeded to save every single object in my scene in a separate folder, not just the selected spotlight objects.
So what's the secret?
  • marblemarble Posts: 7,501
    Sorry I can't offer advice but I am interested to see the responses. I've been tempted to make some props myself but am clueless on all the different save-as combinations. I also wonder whether there is a difference if the prop is rigged - I know it has to be rigged in DAZ Studio not Blender but does it make a difference as to how it is saved?
    Dunno. However, thanks for the years-old post you made showing how to set a keyboard shortcut to zero selected items pose. I was looking all over to see how to do that or make a script, and finally stumbled on your post. Quick and easy. Now I just hit "Z" and BAM !!!
  • File>Save As>Support Assets>Scene Assets.
    edited February 2021
    Richard,
    Thanks, but as I said (and I just tried it again with a minimal scene) it saves ALL scene objects, not just the selected ones, in a new folder it makes in the Content Library.
    Post edited by ebergerly on
  • I thought it did give an opportunity to seelct, but if not save a Scene subset with just the items you want and then save Scene Assets from that.
    Cool, thanks.
