Problem with Predatron Goblin elements
xavieratorxavierator Posts: 161
Dear,
I'm trying to create a Predatron Goblin Scene and some elements don't fit on the figure anf float on the viewport.
Attached sample, only a axe ans shield works fine.
Helmet, boots and other not works fine :-(
Thanks, Xavi
Post edited by xavierator on
  • NorthOf45NorthOf45 Posts: 5,896
    The Fantasy Armor items should "fit to" the goblin figure when they are loaded. If not, make them. Select each piece in the scene tab, then either right-click and select "Fit [item] to..." or look in the Parameters tab -> General -> Misc and see what the "Fit to..." button says. Also Parenting the items to the figure (in addition to fitting) makes a neater scene.
  • The armour items don't fit the goblin, at least the hr version, automatically but as says they can be fittedn to via the Parametrs pane (or by right-click on the items in the Viewport).
    Please remember to put the Viewport in Smooth Sahded mode if you need to show a nude figure, even without any anatomical elements.
  • xavieratorxavierator Posts: 161
    edited February 2021
    Hi,
    A few months ago I could create 2 goblins with all the accessories without problem, now with the new version of DAZ something has changed.
    Perfect, the "Select each piece in the scene tab, then either right-click and select Fit [item] to..." solution works fine.
    Thanks a lot, Xavi
