DIM problem after database maintenance
After the reset of the database and re-import of the metadata (genesis 8.1 starter pack was not visible after installation in the smart content.  The only solution has been the database maintenance process.  Now I can see it) the DIM became slow.  The download is fast and normal as it has always been but to install or uninstal a single asset it takes 5 minutes.  I don't know what happened.  Libraries and manifest folder are always the same.  Does anybody know a solution?
  • The only solution has been to reinstall everything.
    But I wanted to experiment if it has been a random problem or it is a real one.  So in another PC, where DAZ studio and DIM worked perfectly, I resetted the database in the content db maintenance and reimported everything.  Well the problem occurred again.  DIM became slow and didn't uninstal correctly the assets.  I would like to know if anyone has ever had this kind of problem... but maybe I'm asking too much.  The solidity of a software is also in the strengh of its community.
  • OmnifluxOmniflux Posts: 442
    Have you tried "Condense Database" after "Reset Database"?
    I'm not sure if it will have any effect, but it could depending on how Reset Database works...
