Keymate question
CrystalwizardCrystalwizard Posts: 102
i've gotten a copy of keymate and am quite happy with it.
however I have a question.
when I expand an object, I see only these transforms:
X translate
Y translate
Z translate
X rotate
Y rotate
Z rotate
Does anyone know how to get the size transforms to show up?
  • Richard HaseltineRichard Haseltine Posts: 112,143
    I don't have Keymate, but do you have the display of Hidden Parameters enabled in the Parameter pane option menu (the lined button in the top corner, or right click on the pane's tab)? Is there a similar option in the Keymate pane's option menu?
  • CrystalwizardCrystalwizard Posts: 102
    Yes, I do. Not that I can find.
  • rek_2158272rek_2158272 Posts: 0
    There is a dropdown on the keymate toolbar where you choose if you want keys set for translation/rotation or transation/rotation/scale (if I remember correctly). Have you tried to change this to see if you can see the scale properties in the list?
    I hadn't, no. I will try that, thanks.
