Viewing problems
When I create a cube, at Viewport I choose the texture shaded view, when I use the mouse to make any type of movement or change, the cube changes to the Wire Bounding Box view and only returns to the texture shaded view when I release the mouse. This also happens if I choose another type of visualization, while the mouse is activated it goes to Wire Bounding Box. The same happens when I try to move using Parameters. I would like to know if this is a configuration (which I would like to disable) or some program error, because when I started using DAZ Studio, this did not happen. Could you help me solve it?
windows/panes/draw setting
change "manipulation something" to off
