Problem with flat chest morph
Hi
I created a dress with Marvelous Designer, using the body of GF8.
After importation into Daz Studio, this dress adapts perfectly to this body.
After the Transfer Utilily, when I try to deform GF8 with the parameters dials, this dress deforms correctly on many parts of the body.
However, I have an anomaly of deformation, with a flat chest morph.
Indeed, when I apply this morph, it creates a depression, because the part of the dress under the breasts does not move.
In fact, it is logical to have this problem. As the dress is quite loose and does not adhere to the body, the contrast is very important.
I have tried to modify the dress weight map by widening the area of influence of the breasts, but it does not give good results.
Actually, I just want to limit the depression you see in the photo, because this dress is for simulation.
For information, I use the Flat Chest Karyssa 8 morph which is downloadable at the following address:
https://www.deviantart.com/talidesade/art/Karyssa-8-Flat-Chest-Morphs-DOWNLOAD-743018442
You would need to modify the dress shape to fit the morphed figure, then load that as a new morph with the same name as the morph used.
You can select to show hidden morphs then cancel this flat chest morph for the dress
The way how Daz works is by projecting all morphs from the host figure to whatever is fit on it, and you can cancel morphs you don't like. I often do that to fix distortions caused by custom character morphs.
Another alternative is:
Regards,
Richard.
If you are looking to get a good grade on your paper look no further! This write my paper service always delivers an «A» paper. The writers has great communication and always understands what I need. Even though I wrote a similar paper once last year, I already forgot how to do this analysis and understand that it will take too much time to reread the theory and then write the paper based on it. Thanks for making my life easier!
