Unable to add dForce modifier
Hellwolve
As the title says, I am currently unable to add the dForce modifier to items. I'm using 4.12 Pro and simulation for items with 'build in' dForce works just fine; I just can't add it to items that don't have it yet.
I've searched the form and came across this thread:
https://www.daz3d.com/forums/discussion/279601/unable-to-add-dforce-modifier-and-surface-simulation-settings
I checked the places mentionend there (Simulation Settings options, Edit>Object>Geometry, Edit>Figure>Geometry), but I couldn't find the 'add' function, alas. It's strange - I'm fairly confident I had the option when I just started to use 4.12. Restoring the Simulation Settings pane to defaults doesn't seem to help.
Try Window>Worksapce>Update and Merge Menus.
Ah, that did the trick! No idea why it was needed, but it worked :-)
It's used to add new commands to the menus, without losing your own customisations.
Good to know, thanks!
I never knew about this, just thought it was another glitch Daz had to fix, thanks Richard
