Unable to Add dForce Modifier and Surface Simulation Settings
ForestBoyForestBoy Posts: 76
Hello!
I'm trying to follow this tutorial to add dForce:
In the beginning, she right-click the little icon in the "Simulate" pane, and then a menu drops down in which she selected "Add dForce Modifier and Surface Simulation Settings".
I don't see this menu dropping down. Instead, I see this:
And when I click "Simulate", I see this error message:
Can anybody tell me how to add this modifier?
Not sure if DAZ changed something or if I'm blind or if I did something not correctly.
Thank you very much!
Post edited by ForestBoy on
  • Select the dress, go to edit/figure/geometry/add dforce modifyer!
  • Thank you!
  • HeraHera Posts: 1,970
    How do I do this in DAZ 4.12?
    (edit/figure/geometry/ - does not contain "add dforce modifyer" anymore)
  • scorpioscorpio Posts: 8,533
    I have it under Edit>Object>Geometry
    Or with the item selected you can find it in the Simulation Tab
    463 x 642 - 38K
  • thanks scorpio, because in the version 4.14, this is the only place that i found how to add the dforce modifier.
