dForce simulation calculation - single threaded?
Just q quick question, doing a test dForce simulation and noticed that my CPU is not really doing much overall, just the one core is being maxed (GPU is also pretty idle) - is this as expected? I.e. is the dForce simulation calculation single threaded and purely CPU calculated? Just wanted to make sure I'm not missing a setting.
Many thanks.
  • By default dForce will be usign your GPU, but if you are monitoring using Windows Task Manager that may not show up - try checking the different graphs for the GPU in the Perfomance tab (click the arrow to change them around).
  • It's probably using your GPU, and the one thread is managing the communication beteen your system and that GPU. But beware that dForce uses OpenCL, not CUDA, as far as I know.
  • It's definitely not single core/thread.
    1680 x 1050 - 354K
  • LauritaLaurita Posts: 288
    Is it possible at all to use the CPU for dforce simulation? I can only choose between my Nvidia card and an Intel Onboard Graphics adapter. As I am stuck with an ancient 6GB GTX1060 I actually might be better off with simulating on my CPU
    Yes, at least with an Intel CPU  -they have an OpenCL driver, linked here https://www.daz3d.com/forums/discussion/203081/dforce-start-here#latest
  • Many thanks
