• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Morph already posed clothing?
marblemarble Posts: 7,500
January 2021 edited January 2021 in Blender Discussion
I wanted to adjust a dForce drape on a skirt fitted to a posed G8F figure. It didn't work - here's what happened.
I exported the base G8F and the skirt to OBJ and then imported to Blender, made the adjustments in a Blender Shape Key and exported back to OBJ. I then used Morph Loader Pro to import the morph which it did successfully. However, when I try to dal-in the morph the skrt mesh goes weird and looks nothing like the morph I created in Blender. I tried it again with Reverse Deformations turned off (I usually switch that on when importing morphs) but that didn't help.
I do make lots of morphs in Blender but so far I only do so using base figures in the standard T or A-pose. It seems that I have never tried with an already posed figure (although I was sure that I had). Now I'm a little lost as to what to try next. Any ideas?
Post edited by marble on January 2021
  • gregsgraphics_cafd0962a0gregsgraphics_cafd0962a0 Posts: 114
    January 2021
    Does that dForce thing change the subdivisions when you do a drape?  If so, then morphs will not work when you export it in draped form.  I don't know if it does or not, I don't use it.  But might be something to check.
  • marblemarble Posts: 7,500
    I'm pretty sure it is not a vertex count problem because that usually results in a failed import with Morph Loader Pro.  I think it has something to do with Reverse Deformations but I'm not very clued up on that kind of thing.
    I did check the subdiv before exporting from DAZ Studio and reset it to 0 on the skirt. I always do that with exporting to Blender to make morphs.
  • Richard HaseltineRichard Haseltine Posts: 111,315
    January 2021
    Was the simulation still applied when you imported the morph with Reverse Deformations on?
    As far as I know, yes. I posed the figure, draped the skirt and exported each (posed figure then draped skirt) to OBJ files.
    I imported to Blender as I normally would for morphs, created a shape key and made the adjustment before exporting back to OBJ. I then used MLP to import - first with Reverse Deformations set to "Yes" and second time to "No".
    The effect is that it tries to morph the skirt into the adjusted shape as though it were starting from a un-posed position (I think). So you get the pose plus the pose, as it were.
  • lilweeplilweep Posts: 2,864
    January 2021
    i dont think this is a question that should be in blender subforum, since it's just a question about how to use Daz Studio's morph loader pro.
    If you have Reverse Deformations set to 'Yes' in Morph Loader Pro, then it should only add the changes from the current shape. It will work for both posed garments and unposed garments (i.e., A pose, T pose).
    Maybe you should import the .obj file directly into Daz Studio and see if it lines up with the current posed figure you have.
    also, posting an image of what the garment looked like with the new morph set to 100% wouldnt have hurt diagnosing the problem.
    January 2021
    Don't you just love being lectured?
    I posted it here because I am using Blender to create the morph. I don't know whether it is a problem with the morph itself or the workflow I described or Morph Loader itself - if I did, I might not need to ask the question. After it didn't work, I scrapped the whole scene and the Blender file so I didn't have the screen shots to post. If I need to, I can recreate the scene but the responses seem to indicate that the description was understood. It was only an afterthought to post the question because I figured that others might hit the same issue sometime.
  • plasma_ringplasma_ring Posts: 1,027
    January 2021
    I just did this for my It's Raining Men entry. My process was:
    • Unparent posed clothing item
    • Export at base res (I also exported a version of the posed character along with any props they interacted with, for reference)
    • Import to Blender and edit
    • In Daz, unfit the clothing item from the character and import the morph
    I got warped results as long as the item was still fitted to the character, because it was basically adding the morph to the autofit results. Since I wasn't moving the character again this wasn't a problem.
    January 2021
    Ah thank you  ... that makes perfect sense.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
