Trouble installing plugins
eddie1227eddie1227 Posts: 5
I've had the error message below with every plugin I try to install. Dynamic control, decimator and measure metrics. My daz3d is up to date, version 4.6.3.52, so I don't believe that's the issue. I believe others have been having this issue as well, so Id be happy if there was some type of solution.
516 x 130 - 18K
  • Richard HaseltineRichard Haseltine Posts: 112,275
    Are you installing both plugins and DS the same way - both with the Install Manager, or both via the separate installers? Are you sure one isn't the Public beta and the other the (newer) production release? Both 64 bit?
  • eddie1227eddie1227 Posts: 5
    edited September 2014
    Well, I Installed daz3d using the install manager, and the plugins using the installers, but I had no idea that would effect it in anyway. If I uninstall daz3d and reinstall will it also delete any plugins I already have?
    I just installed daz again in a new directory and it works just fine! thanks.
    Post edited by eddie1227 on
