Camera Parameter Help
digitaladiposity
Hi, I'm wondering how I accidentally hid the Camera: Lens parameter set in the Parameters tab, it's not listed when I select a camera. How do I get it back?
[Edit] It looks like I hid it somehow, I found it by switching the "show hidden parameters" preference. The only problem is that the hidden parameters' names are in a dark grey that's hard to read against the black background. Is there any way to change this appearance, and how do I get Lens to display unhidden?
[Edit 2] I opened an old file and selected the camera in it. Lens is displayed by default, everything is normal. Are the choices to hide/unhide parameters saved with the scene file?
397 x 481 - 36K
375 x 450 - 28K
Post edited by digitaladiposity on
Did you change the Render Engine in Render Settings?
I didn't intentionally make any settings changes, and I was in Iray mode the last time I checked.
No luck reproducing the problem, thankfully everything's back to normal.
I'm regretting cropping the screencap so tightly, the full screen could have explained a lot with the Render Settings tab open. Live and learn.
