Eye Issue
dc19dcdc19dc Posts: 22
Hi,
I'm not sure why the eyes keep glowing when I render, I haven't touched any of the setting.
1366 x 768 - 223K
    What figure is it, and is it the default skin?
  • dc19dcdc19dc Posts: 22
    It's the standard G2F figure and skin, but I did use the "New Surfaces For Old" Script to use a V4 skin. I've used this script before and its not caused a problem before.
    but I did use the “New Surfaces For Old” Script to use a V4 skin
    It sounds like the script is the problem.
    Where did you get this script from, I can't find it anywhere, and what V4 skin are you using?
    You could try changing the Opacity setting for the eyes in the Surfaces pane to see if that helps?
    Looks like you might need to turn off either the cornea or the eye surface.
  • V3DigitimesV3Digitimes Posts: 3,502
    I think it is yes.
    You should select in the surface tab "Eyereflection" (and eventually "cornea"). Then in opacity, lower opacity somewhere between 0 or 10%.
    The thing happening is that older generation did not have equivalent surfaces for some new surfaces introduced in G and G2.
    It could be enough. If not just leave a message here, there might be additional things to do.
