Install Manager register
Hi there!
I've installed all my DAZ library on an SSD, so, when i updated mi PC from Win7 to Windows 10, i still have my library installed on my secondary SSD.
But once i downloaded DAZ and Install Manager, it doesn't recognize my installed products and tell me they are ready to download. I wish to know if there's any way to update or synchronize my DIM register to my Runtime folder to fix that.
Greetings!
  • Did you copy the Manifests folder from the old machine, and if it is in a non-default location have you told DIM where to find it?
  • namtar3dnamtar3d Posts: 254
    Unfortunately i did not, :( i don't have my old register.
    Richard Haseltine said:
    Did y
    ou coddpy the Manifests folder from the old machine, and if it is in a non-default location have you told DIM where to find it?
  • I'm afraid you will need to reisntall then, though if you reimport metadata* (assuming you haven't) the content should work in DS in the meantime.
    * Content Library option menu, the lined button in the top corner or right-click the tab, and select Content DB Maintenance; in the dialogue check reimport Metadata then in the enxt dialogue use the select all boxes.
