Missing tools from Geometry Editor
Since the update I seem to be missing Hide and Delete, along with a few other tools from Geometry Editor.  Have they been moved or removed?
I ended up having to use Surfaces tab, turning glossy color to black and cutout opacity to 0 for the items I needed today, but what about tomorrow?
Definitely more time consuming
  • TaozTaoz Posts: 10,401
    Everything seems to be there in my DS 4.14.0.10
  • weird, thanks Taoz
    guess I will do another uninstall and see if I get anything back this time.
  • check plugins in case you accidentally disabled it
  • You actually have the Geometry Editor? If so I suspect it's in Vertex or edge selection mode - the options change depending on what you are selecting. The mode can be set in Tool Settings or in the right-click menu.
  • Thank you Richard,
    Yes it was set to Vertex selection under Selection Type and not Polygon selection.  Once I changed it 'poof!' my Hide and Delete options came back!
    It must have defaulted back to that after the update, as that is when it started.  I must have 'set it and forget it' so long ago, that I did forget it. Haha!
