Transfer rigging pose issue
FSMCDesignsFSMCDesigns Posts: 12,859
I have an .obj i need to use for a project and want to add basic rigging to it to pose it. I followed a couple of threads on transferring the rigging from genesis (pose genesis to match the obj and then transfer utility). Problem is, the obj isn't in a T-pose and when i transfer the rigging, it only transfers in the default pose genesis is in. Any ideas how to fix this or transfer another way.
  • Richard HaseltineRichard Haseltine Posts: 112,305
    You need to adjust the shape or to edit the rigging on the limbs after transferring - I'd suggest that adjusting the shape is the lesser evil if it's simply been made in an A pose or the like.
  • BejaymacBejaymac Posts: 2,020
    Using an older version of 4.6 so I don't know if it's still there, but you'll get better results if you try "Edit > Figure > Rigging > Transfer Rigging (Figure Space)" instead of the Transfer Utility, it transfers the rig in it's current state (pose) to another mesh.
  • DushkaDushka Posts: 17
    Could you please explain how to do this, Bejaymac. I cannot figure it out at all. Whenever I try to do this, I get an error message saying, "Select a source figure then a target to use this action". How does one do that?
  • 3 days trying the same... select first, select second... nothing
