Metada Failure
petes imagespetes images Posts: 213
Hi, when openeing Daz 14+ i always get the message, in the status bar "Metada 2 files updated, 1 failed". any idea why? this is probably why Octane Render, and Actual Eyes will not work, and the plugin for Octane Render will not load. I have also put a ticket in for this. Thanks
Edit: sorry should have said 1 Item updates successfuly, 1 item failed
Post edited by petes images on
  • Richard HaseltineRichard Haseltine Posts: 111,384
    edited December 2020
    IOt means what it says - when you connect to Daz (which is optional) DS looks to see if the product metadata has been updated compared to what it has. if there are metadata (that is product info and categorisation information) updates then it tries to download them. If that fails then it lets you know. At worst the failed product may not show or may not show correctly in views that use metadata (anything other than the Daz Studio Formats/Poser Formats lists in the Content Library pane) - it will have little impact on the use of the content, though there are features which rely on metadata (for example AutoFit - though it's criticial only for the figure that is going to wear the clothing).
    the log (Help>Troubleshooting>View Log File) will tell you which product failed to update.
    ok, thanks
    ok, thanks
    Just checked, the only warnings i am getting is what appears to be a common fault is the following
    2020-12-07 09:30:05.908 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: Date: Mon, 07 Dec 2020 09:30:05 GMT
    2020-12-07 09:30:05.914 Successfully created OpenGL viewport for Viewport3.
    2020-12-07 09:30:05.914 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: Server: Apache
    2020-12-07 09:30:05.914 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: Vary: Accept-Encoding
    2020-12-07 09:30:05.914 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: Content-Length: 226
    2020-12-07 09:30:05.920 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: Connection: close
    2020-12-07 09:30:05.920 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Got an unknown command from the persistent connection: Content-Type: text/html; charset=iso-8859-1. WIth a load of other lines regarding the same
    Octane Render just will not work and is greyed out in DIM, also the plug-in will not show despite downloading from the site
    thanks
    pete
  • Does the Octane plug-in even appear in DIM?
    Does the Octnopane plug-in even appear in DIM?
    No, it never did
