Parameters Tab Issue
bobmale
I do not know if it is just since switching to Daz 4.14 or since I had to reset my workspace layout, but my Parameters tab is now totally divided into the property groups. Basically, you used to highlight the top listing of the parameters such as Genesis 8 and see all of the dials for the figure. Now I have to select Translations to see those, then switch to Rotations to change those. While that is a small inconvenience I have to know exactly what group a dial is in to change it. Search is entirely broken because you have to be in the correct branch of Actor (for example). I have to open section after section to find anything. Any suggestions how to fix this?
Post edited by bobmale on
Check Show Sub-items at bottom-left of the pane.
Thank you, Richard!
I had noticed that Surfaces was acting normally.
