Vertex indices on Geografted figures
shoei321shoei321 Posts: 113
edited December 1969 in Daz SDK Developer Discussion
I have a figure with a Geografted part. When I call :
figure->getObject()->getCurrentShape()->getAssemblyGeometry();
I get a DzVertexMesh back that includes the entire geometry (original figure with geografted part). Given a vertex index in that mesh, is there a way to look up the corresponding vertex index in the mesh that was the source for the geografted part?
Thanks
  • rbtwhizrbtwhiz Posts: 2,482
    Don't have time for a more detailed response... but also don't want to keep you hanging...
    There isn't a very convenient way... but it is possible.
    Using the assembly mesh, the vertices are ordered thus:
    - All host figure vertices, then each Geo-Grafted figure's vertices
    - Geo-Grafted figures are stable sorted by objectName, then vertex count; those that end up with no geometry do not contribute
    - The original list for stable sorting is in "fit to" order
    Hope that is enough to help keep you moving...
    -Rob
  • shoei321shoei321 Posts: 113
    Thanks Rob, that does get me a bit further.
    My next blocker is this -- I need to find the graft vertex mappings between the parent figure and the grafted mesh. As I understand the geografting feature, there is a set of faces shared between parent mesh and the graft mesh -- how do I find the mappings between the two?
    When I look through the QtScript members on the object returned from DzShape->getGeometry() I see these two that look promising :
    weldGroupsByMap(DzFaceGroup*,DzFaceGroup*,QVector)
    weldGroups(DzFaceGroup*,DzFaceGroup*,QVector&)
    Am I on the right track here? If so, can you provide some guidance on how to use these methods?
    Thanks
